P.W.R 96 xp 800
Check out this project.
I can see why seadoo never put a 951 in this kind of body style out into the market because it is such a tight fit barley enough room for the beast. I had to leave the pipe inside the hull then drop the block in otherwise it wouldn't fit. The electronics and motor are from a 1997 gsxL we call them 1997.5s because seadoo made them during the year that they already had a gsx out on the market. We also put the gas and oil tank from the gsxL in there as well. Also we put the info gauge from the gsxl on the panel where it gives you the option of adding it right next to the dess key the buttons to control it are under the stering cover. It also has electric bilge right next to those buttons. I also had to enlarge the jet pump area to fit the 951 jet pump. I personilized it a little bit by adding a 951 pipe extension and a skat trak racing pump and impeller and aftermarket carbs and flamearrestors. To tell you the truth I have not ridden that thing in 7 years I just got around to bringing it back from a long cold sleep. It needs the carbs cleaned and needs to be summarized but when that thing did run I got it into the 70s hopefully I get it back into the water soon so that I may enjoy it once again.
Just thought you guys would like to see it. feel free to ask questions or did anybody else do something similar to this on this website?
