It’s possible maybe, do you know of any way to tell? If I could get the dimensions for the bearing off websites I’d be in the money but nobody put that’s info, just part number.
I know very little about its past life. I bought it on an impulse. It ran but bogged down, started doing my research. Changed out the grey fuel lines. A friend talked me into doing pre-mix which I regret. After the line swap I rebuilt the carbs. It fired right up and ran pretty good, when I idled back to the dock it wouldn’t start ( fouled plugs) I did that song and dance a few times. Then the last time I took it out I almost sank it :|. I the through hull connection basically disintegrated. So in the process of putting the aluminum through hul fitting in I decided to pull the engine and go through the top end. It also gave me access to clean the inside and get all the bolts out that have been dropped in it.
