Hello all. Hoping to get some help and advice before I totally give up. Due to a completely burned/low compression MAG side piston, just completed a top end rebuild including new jugs, pistons, etc. Ran better than new first time out for a couple hours. Zero issues. Took it out today and after about half hour of running great, engine stalled. Tried to start and engine turned over a few times. Second attempt, engine felt like it looked up. After trailering, I pulled plugs and engine turned fine. I installed PTO side plug and engine ran on that cylinder. I replaced CAM plug and engine turned without starting. Basically, the same scenario which prompted the top end rebuild prior. Just a side note. Before top end rebuild, I did have the carbs rebuilt by a very reputable shop. The first time I took it out after carb rebuild, engine acted similar to today. Low compression/burned CAM piston discovered after removing head. I have been checking compression almost daily since I completed rebuild. Solid 150psi both sides. Unfortunately, after problem today, 130psi MAG side/150psi PTO side. There is obviously an issue with the MAG side. I may be overthinking again. Could that side be running too lean? Possibly lack of oil to cylinder? May be a dumb question. Is there a way to confirm oil travel to cylinder? I have attached before and after pics. The low compression MAG side does not look too burnt and it appears the PTO side piston has a bit more oil barely visible on top. Also, engine turns fine with head off. The GTX is like new cosmetically. Hate to give up on it. Any help or ideas greatly appreciated.
