Carpetcolor
New member her just bought a SPI and having trouble with overheating. Boat ran fine for about 20 minutes then got overheat alarm and steam coming out of one of the two pissers in back. I quickly idled to dock and shutoff. Back home I noticed there was a clear hose coming from under exhaust manifold then exiting rear right hand side of ski attached to a 90 degree elbow. In other words its venting just across from drain plug. It appeared to be at least partially packed with sand. Could this be cause of my overheat problem? I did pull compression with a tester I bought from Harbor Freight said 120 across both cylinders. Thanks in advance for help.
