Ok so i was getting ready for the season and put new wear ring on and changed pump oil and put in a new rectifier because my battery keeps dieing.
Finish installing everything and start the engine on the hose runs fine for 30 seconds. In doing this to get pump oil throughout bearing . Then i shut it off and add more oil. I do this 3 times until its topped off.
On the last start after cleaning up before i walk away . It fires up i give it a little gas then it shuts off dead. I goto start it and the engine is seized in place. ...im getting really frustrated at this point after fixing every thing.
Pull front flywheel cover off and the starter is stuck to the flywheel it did not retract.
CAN THIS RUIN MY ENGINE???????? I REMOVED STARTER AND NOW THE PTO SPINS A LITTLE BUT NOT ALL THE WAY AROUND.....DID THINGS GET FD UP INTERNALLY????
ALSO MY TACOMETER STOPPED WORKING AFTER REPLACING THE RECTIFIER AND SPARK PLUG WIRES???
PLEASE HELP I HAVE A CAMPING TRIP ON WEDNESDAY
