1991 Seadoo GT will not get gas to carb.
KCinALA
I started to have a little trouble getting my seadoo running. Initially a little starer fluid in the carb. would do the trick. However, at the end of the summer we were riding and it started to act like it was running out of gas while operating at speed (It had a full tank of gas) . I tried to choke it and switch between reserve and main tank. It finally quit and would not restart. I checked the fuel line and filter. There did not seem to much gas in the filter bowl. Right now I assume the problem might be the fuel pump. Unfortunately I don't know where the fuel pump is located. Can someone give me some pointers or ideas what else to lok for?
Any help will be greatly appreciated.
Thanks,
KC
I would check and replace all the fuel lines and the inspect the pet cock for reserve/ on position. The fuel pump is on the linkage of the carbs When you clean the carbs, you'll find it. The pulse line for the fuel pump, goes to the crank under the carbs.
Karl
