08 GTX wants to go reverse
doclomlom
Hi There ... I have a problem I can't seem so solve! Yesterday I was running about 50mph on calm water and suddenly the machine bogged down, and got very hard to steer. I was in deep water and had been in very rough (but fun!) water earlier in the day. Now when I run the machine, the steering veers to the left while the machine goes straight, the steering is very stiff and relatively unresponsive and the reverse lever creeps up the faster I go, max speed about 27mph and the water jet at the back looks like water in a blender. At very slow speed reverse is fine and responsive.
I pulled the machine and out of the water it all looks fine. The reverse gate seems fine, lever and mechanism to it look fine from inside, the steering seems fine, all the mechanics of the steering and reverse seem absolutely fine and feel fine out of the water. The impeller looks good, nothing stuck in the intake.
Any ideas?? Thanks in advance!
It's an '08 GTX 155 with 260 hours, I've had it since new and its very well taken care of.
Greg
Update -- I noticed that I'm missing the two upper bolts that mount the external propulsion housing - one is missing (I can see the hole and threads) the other appears broken off in that all I see where the bolt should be is metal, unless this unit has only three mounting bolts, which I doubt!
For those interested -- I replaced the missing bolts and all is good. It's a very easy job, just be sure if you do it yourself that you have the rear brass square thread for the bolt to thread into.
Clmboating -- which machine did the bolts go on?
