05 RXT Reverse Cable Issue
enroth48
Just want to say all who are participating with this good info. are AWSOME!!
The reverse cable lock, item #30 per parts manual.."threaded insert/nut" for lack of a better description broke off in its housing today. I was able to remove cable from reverse scoop and said hardware. The Doo is currently on a boat lift over water, luckily I did not drop anything..yet! Anyway is there a way to remove the threaded piece left in the "fitting", could not find item number online, that goes through the stern? I believe I can pull the cable toward the bow enough to get a eazy out in to remove, or do I have to pull the rear of pump housing off or whatever. If I have to remove from the lift will the bilge fill with salt water and create further issues.
I can't help you in this case, but [MENTION=16022]Dr Honda[/MENTION] will be able to help for sure...
