Seadoo rxdi
I just bought a used rxt 215 with 220 hours on it. I am trying to figure out why I can only get 59mph at 8000rpms. This is with a full tank and the water was quite choppy. But i thought these things should reach 70mph roughly?
Here are some pics of the impeller and wear ring. My only guess so far is that slight bends in the impeller trailing fins could be causing it? Or could it, they look rather minor. The wear ring looks fine.
I did find that the green cone had backed off and was halfway down the driveshaft. Could this be a factor? Should I just leave it off now that I have the pump pulled off?
Am I wrong to assume this machine should do closer 70 at 8000rpms?
The impeller is a 13/18 concord.
Edit: I determined the speed from my phone GPS. Not the speedometer on the ski
