05 RXP--Maintenance--
dharrison0001
Getting ready to hit the water next week. Would like to make sure I have boat ready to go--
Outside of the obvious (new filter and oil, coolant level), would anyone advise as to other fluids/grease points/jet pump oil?--anything I should check or change? Doesn't appear owners manual covers anything in detail.
Would appreciate any input!!
Dave
Depending on how many hours on the seadoo will determine what needs maintenance. The Owners Manual is not of much good for maintenance. Here is some information on the "Premium Membership";
As a premium member you can down load a authentic seadoo SHOP manual from the seadoo manual library. In the library is a variety of manuals for almost all years and models. You can view as many as you like on line as a PDF file, or download it and print it for your personal and private use. There are operator manuals and repair manuals for you to do your own repairs on your seadoo. The repair manuals have everything from troubleshooting, repair procedures to winterizing. It contains wire diagrams torque specs and pictures for disassemble and assemble instructions. In the spec sheets it tells everything needed to maintain oil changes, spark plug gaps, carburetor rebuilds and impeller wear ring tolerances. Click on the "Seadoo Manuals" link at the top of the page for more details. If you need any help or get in a jam, we are always here to answer your questions too. Premium members get priority when it comes to getting quick detailed answers.
Karl
