USC Justice
I have an acceleration issue with a project ski that I have been working on. It is an 02 GTI LE. I bought it with a blown motor. Hull was in beautiful shape.
The problem is this. In the morning (or whenever), I first jump on the ski, everything is fine. Fires up on the first push of the button and will get up and go and plane out and get up to speed. It is from the start just slightly slow on the pop up out of the water. The problem is that as the day goes on, the amount of lag between grabbing a handful of throttle and the actual acceleration lengthens. After running the ski for say an hour or so at ½ to full throttle and then you slow down for a no wake zone and then accelerate again, it may take as much as 30 seconds from the time that you go to full throttle until the ski actually responds and comes up and out of the water.
I know that an aftermarket impeller (like a skattrak swirl) will improve pop up and so on out of the water some. I think this is something else.
Here is what I have done in the process of working on the ski…
SBT Motor
New Wear Ring
New Pump Oil and O-Ring
New Fuel Lines (just to be on the safe side)
New Oil pump assembly
New Mikuni Carb (was told the old one was beyond saving)
New Starter Solenoid
Any thoughts as to what might create such a condition? I idly wondered if it might have been the MPEM for some strange reason, so I have swapped the MPEM from my 99 GTI into it (Hey, same motor, so may as well). This resulted in no change whatsoever.
SBT Motor
New Wear Ring
