RESTO 01 GTS steering
CRei
Messages
135
Likes
0
Location
Jersey Shore
#1
Hey all removed the steering cable that is frozen from the ski. Now the steering head is tight to turn left right. Ski sat for like 3 years covered, is there any way it will free itself up? Is it a job to replace ? Thanks
GGuillot
Messages
519
Likes
78
Location
Alabama
Water Crafts
1997 GTX
1996 GSX
#2
What did you do when you removed it? I've never faced this issue on a ski particularly, but other cable controlled machines. You could spray some cable lubricant on each end work it in and see what happens, not easy for a long run cable, but it will work itself in and help the situation. Otherwise, you'll need to replace it. And no, not a difficult job to do, you'd just need to find a replacement cable. Maybe double check to make sure it's not binding anywhere.
GGuillot
Messages
519
Likes
78
Location
Alabama
Water Crafts
1997 GTX
1996 GSX
#3
Not sure on the 01' GTS, but on my 97' GTX seems I remember both cables being the same, you could swap them, since the reverse bucket is less critical than steering.
mikidymac
Moderator
Staff member
Moderator
Messages
9,227
Likes
685
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#4
Is it the cable or the actual steering nozzle that is hard to move?
CRei
Messages
135
Likes
0
Location
Jersey Shore
#5
Sorry my bad, the cable is frozen I have a new one coming. So with no cable in the ski the handle bars are real tight to move left and right. Hope this helps
GGuillot
Messages
519
Likes
78
Location
Alabama
Water Crafts
1997 GTX
1996 GSX
#6
Put some grease in the steering shaft area.
mikidymac
Moderator
Staff member
Moderator
Messages
9,227
Likes
685
Location
California
Water Crafts
2003 GTI
2001 XP
1996 XP
1996 HX
1991 Superjet
2001 Superjet
#7
As the previous post says, remove the steering shaft and clean and grease it with a marine grease like the Seadoo XPS synthetic grease. The bars should turn really easy.
Adsense
Usergroup
