XP Venturi/Plastic Assy. Stuck Bolt
a2zed99
Have a '95 XP and the venturi cone attached to the jet pump has a bolt that turns but won't come out. That assy is plastic and apparently the nut is loose within the housing. Thanks in advance.
Try to jam the nut... or drill into the nut from the side... and let the drill bit hold it.
Great suggestion on your method -- though we ended up cutting the head of the nut off and tapped it down the hole and out.
