get_real
Well I've had my 96XP for about 2 months now....it runs great and gets up to just shy of 9000 rpm. But every once it awhile it will still stumble and won't accelerate past 3000 rpm.
If you just hold the throttle open it won't clear up. But if you turn it off for 30 seconds then start it back up and accelerate quickly the bogging goes away. Sometimes you have to repeat the procedure 3-4 times but eventually it will return to normal.
I noticed today that if you hit a wave while trying to accelerate from a bogging episode and suck some air in the pump it won't clear the bog. It has to accelerate after starting without sucking air.
Curious if anyone has an idea of what might be wrong or has ever had similar symptoms? I was hoping it would clear up with more use but no dice!
Sent from my LG-VM696 using Tapatalk 2
