Can anyone tell me where the oil bleeding screw is on the oil pump? I changed the oil and lines. Now I need to bleed it. (ive already primed the 3/32 oil pump lines. I appreciate all y'alls help.
Here's a picture of the oil pump. The bleed screw is just under the injector line on the front of the pump. I think there's a better picture in the service manual.
If it is like mine on a 787 it's the top silver nut in-between the 2 yellow hoses. If yours is a 720, just look for something similar.
As sure that Lou or someone will pop in with a correct pic for a 720 if needed.
Be careful and not tighten it too tight as it will break off.
Yes, I've already change the zip ties to a smaller one
***EDIT****
He was posting at the same time I was.
