X Charger upgrade
KK40384
Premium Member
Premium Member
I've been toying with the idea of upgrading my RXT to a X charger. In order to do so I need bigger injectors. Is the factory intercooler adequate enough to handle the factory boost of the x charger or do I need to upgrade that too? Common sense also tells me the ECU needs to be reflashed to work with the bigger injectors. Anything else I miss?
I upgraded 06 gtx limited a few years back with a x-charger all you need to run it safely is a 4" air intake,42# injectors, catch can, and a 14/19 impeller this is a very safe mod setup and I have put over 300hrs. with it just remember service SC and rebuild every 100hrs.
I didn't plan on upgrading the intercooler at first. Maybe down the road if that isn't enough.
Ok, you'll be fine then. I'm moving this thread over to the performance forum as well.
I may be doing this mod sooner than later so stay tuned for updates and install instruction video.
What kind of gains did you see over stock with this setup?
