Wot
Haribo
Hi all little help required
I have recently traded up to a wake addition 155 the problem I have is I am only getting 6300 rpm flat out had a new ware ring fitted last week prop checked all good also throttle position sensor reset cable checked no codes stored at all idles lovely and with throttle all the way back there is no free play thinking this would solve my problem but alas it did not ski runs perfect starts on the button everything works but I am only getting 41 mph on gps as I did not trust the ski Speedo from what I understand I should be getting about 7300 rpm and about 55 mph someone may correct me if I’m wrong any help would be very much appreciated
I have a 2002 GTX 4-TEC 155. Same exact symptoms as you have. It will hit 7500 for a second but right back to 6500 as it planes out. I do have the two beeps repeating every three seconds when the dess is attached and engine off
