I have a 96 sea doo xp. It ran fine 2 yrs ago, it would not start so the people I got it from let it sit up. I removed the carbs, cleaned all internal parts. The fuel lines were deteriorating so I replaced them. Then new plugs, clipped the ends of the wires. Brand new battery. Now it runs great... out of water. When you drop it in water it slowly pulls up to 4000rmps and stays there. No beeps at all, but the fuel light stays on and it is full of gas. I checked did the rectifier test and it is a constant 13.8 volts. wear ring looks good, not much room between impeller and ring. There is a bit of a rattle coming from the impeller area. Not sure why and I am running out of ideas. Help Please.
