coolantflush
i read the manual wrong.....2003 xpdi......it said take the tube off of the bottom, an hook up a tube with a half in diameter, but i hooked up a tube back to the regulator i pulled the bottom tube off of, an then dumped about four gallon of antifreeze mixture, but then realized, i hooked the tube up to the exhaust an dumped it all in there, an maybe thru the top tube above the bottom tube i hooked to.....i took the clamps offf the exhaust tube by the back an got out about two gallons an flushed about one more galloon of hot water thru the tube i originally poured into, so now what should i do, go put it in the lake roll it counter clock wise an seee if any got up in to the cylinders, but not sure if it rolled anywher else in the motor from that top tub in the regulator if it got thru....any knowledge on this screw up.......i was a bit tired an read the directions wrong.......how do i pull myself out of this one without any damage....?..thanks any help would help...an can i move this to the two stroke thread?
