Tools needed:
Flat screwdriver
Wire cutters, or knife
Medium size funnel
Hose Pincher (Sea Doo p/n 295000076)
Parts needed:
1 gallon - Antifreeze mix (50/50 or as recommended)
Sea doo Lube (p/n 293-600-016)
Flush hose
Fuel Stabilizer (p/n 413-408-600)
Procedure:
1. Estimate the quantity of fuel in your tank, and add Fuel Stabilizer as recommended in the directions on the container.
2. Remove the air silencer cover on top of the carb(s)(black plastic on newer skis, blue alum. on older ones).
3. Attach the flush fitting to the connector on the ski, and start the engine. Immediately turn water on, and bring engine up to approx. 3000 rpm (half throttle). Spray Sea Doo Lube into the carb opening(s) for 30 sec., then shut fuel valve off. Continue to spray Lube for another 30 sec. As engine starts to die, make sure to turn water off immediately, to avoid engine damage. (reminder - never run engine longer than 5 minutes, or jet pump bearing damage will occur).
4. Remove the spark plugs, placing the plug wires on the grounding terminals, and spray some Sea Doo Lube into the cylinders. Crank the engine over a few revs to distribute the Lube onto the cylinders. Reinstall spark plugs.
5. Jet pump oil should be changed at this point. See the Pump Oil Change section.
6. Seal (if your ski has the type which requires lubrication) and PTO should be greased (this procedure is on the way).
7. Locate the main water lines where they attach to the jet pump and exhaust fitting. The inlet hose runs from the pump and splits into two hoses and connects to the pipe on most models. The outlet hose typically runs from the head to the exhaust fitting. The third hose is a drain hose (clear, usually) that runs from under the exhaust manifold to the exhaust fitting on most models. Remove these hoses where they connect to the pump and the exhaust outlet at the rear of the engine compartment. Tie these hoses so that the ends are above the top of the engine.
8. On the water inlet hose, follow it to the pipe and note where it splits and connects in two places. Install a hose pincher on the smaller hose that connects under the pipe (closest hose to engine). This keeps antifreeze from entering the cylinders, so don’t skip this step !
9. Locate the water inlet hose (the one that was connected to pump), and insert the funnel into the end of it. Pour antifreeze mix into the funnel slowly until you can see antifreeze mix rise above the top of the engine in clear hose.
10. Leave these lines tied for the winter (if they are reattached, the mix will drain out).
11. An additional procedure that is recommended, is to drain the muffler (located behind the pipe). this involves removing the inlet and outlet exhaust hoses. Next, you need to remove the tie-down strap. Remove the muffler, and pour out any water. Reinstall the muffler in the reverse order.
12. Drain and dry the engine compartment thoroughly. Wipe any remaining water off the engine, and spray engine, and any exposed metal parts with Sea Doo Lube. Be sure to spray the carb and cable attachments.
