Hi,
I have now checked the temperature sensors.
The one at the exhaust system didn't work correctly.
I also think it has been some small leakage around that sensor.
The threads look corroded and very bad.
I switch place with one of the other that worked correctly and added some new sealing.
Now after a quick test it doesn't smell like gasoline from the exhaust.
It is smelling like "normal" now.
But there is still some smoke.
I need to test it in water also but for the moment it is to cold.
Thanks all for your help and input!
What is the 4th sensor you are thinking about?This should narrow your investigation to 1 of 4 possible sensors.
