Where do these 2 wires go?
paulo93gtx
Where do these wires go?
The purple and the black?
If it's any help purple is usually the +12 volt and black the ground. Maybe power to the gauges, from the picture I can't tell where the connector is located.
Lou
No, i had the whole ski apart so i could clean the carbs and replaced the fuel lines. And clean the crutted out gas tank. She would stay running the other day so i just got her back together and she sounds better then ever
What? Wires to the oil pump? I don't think so. The only thing connected to the oil pump should be oil lines and a throttle linkage cable.
The oil sensor is in the oil tank not the pump. The oil pump is on the motor.
Sorry, i confused myself. Those two line go to the lower right side of the oil tank.
Mine also has a red wire connected to the + side of the battery and the gauges I think but from your picture, it doesn't look like it (but I am mentioning just in case).
Benji.
That makes sense. Just didn't want there to be any confusion to others here that may be reading to learn. Glad you figured it out.
