Ok... First, only part of the pump assy on your yr/mdl that gets silicone, are the 3 protruding stems that go thru the hull. The nozzle assy that bolts to the pump does not get silicone. Since the pump has been removed, the lip of the wearring is done, thus, the neoprene seal comes to play, let alone, should always have one anyway. Hell, I install them on every pump minus the 951.... Your choke assy, remove the airbox for easier access, and find the appropriate Allen to stick into the brass bushing to turn the set screw, so that the choke cable end isn't pulling butterfly closed....
