You use the correct tool to replace the rubber plugs that secure the plastic check valves in carbs? The low speed has check valves too. Clean them so all 3 low speed holes flow cleaner? Remove jets and clean their circuits? POP OFF NEEDS CHECKED. That is a basic part of rebuilding the carbs. OSD.com has tester for $25. It can be used for testing the fuel circuits and hull vents.
I have wrenched: Cars, plow trucks, tractors, lawn equipment, motor cycles and plumbing. These critters are a different breed. Listen to what we have to say. We have been there, done it !
