I've been having intermittent power issues and low top speed that wasn't solved by a carburetor rebuild.
Compression was reading at 135psi and 140psi. Pulled the coolant block and the top off the cyclinders and this is what I found.
What does this indicate about how the motor is running? What should I look at specifically as the source for my compression loss?
Any insight is appreciated.
