My GF's bungs leakedover the winter last year so this year I left the oil cap cracked open. We'll see this spring if it worked.
LOLOL yep!!!:cheers:
You put a rag over the spark plug holes and turn it over...first w/o then with the throttle wide open. It will pump it out. Tipping it on its side and cranking works good too.
I use Starting fluid to get it going...there is so much oil still you are not gonna do any damage. Typically you want to use mixed gas to start a 2 stroke b/c starting fluid will wash away your oil film.
