I think the CDI is ok. Fail's the manual's test but works just as well as the one I have in there. But then again the one I have in there might not be good either
Its just weird...
Had the head off to change the o-rings and there was a problem with the carbs that was fixed with rebuilding the mag carb.
Also I had the pop off so high that it was running lean but it was on both.
Since then I've gotten the carbs to be somewhat manageable.
Everything above 1/3 throttle or when on the main jet or raves open, Not sure which it is but its smoothed out after that.
If it was an intermittent crank seal I would have hoped to see some evidence of what to look for.
Pulled the engine out tonight (I'm getting good at this lol)
Going to replace the mag gasket and seal. Also the rotary valve , valve cover, O-ring.
But first I'm going to make some blanking plates to do a leak down test. Hoping something will start hissing and maybe an AHA moment will hit me.
Got an OEM valve this time!
Started reading up on how rotary valves work. I guess at high rpm's its inertia that pull's the new charge in and at lower rpm's its the low pressure that draw's it in.
Maybe there is a problem with the signal. As in the engine want's to pull in a new charge but the valve is allowing a back flush enough to equalize the pressure or cause it to reverse for a second.
