grusnak1001
I'm trying to figure out my electrical problem. I thought it was the solenoid, but when I installed the new solenoid I got same response (nothing). I bought 2 new solenoids figuring at least one of them should work and tested them both with a multi-meter OFF THE SEADOO and they both failed. WHAT AM I DOING WRONG? Here is what I did....I set the multi-meter to the lowest ohm setting (200). when I touched the 2 probes (one on each solenoid terminal) I got no reading on both. I know the ohm meter works because when I touched the 2 probes together, I get a low reading (which is what is expected). can anyone verify if both are bad or am I doing something wrong?
