PRAIRIEOUTLAW
I bought a 96 seadoo gtx and have run into something that makes me think I have a problem beyond carb settings. The compression is good, in fact it WAS a bit high but I'm sure that was due to sitting for a prolong period of time cause when it first fired off it smoked like the woods were on fire.
Anyway, I cleaned the carbs and did a rebuild. Everything is clean. Small jets and all. Set carb to spec at 1 turn slow speed and fully closed high speed. Took it out and it started. I adjusted the low speed and idle to get it right there. All was good. Then had the stumble when you go closed throttle to full throttle. It would pick up but I was sure it was lean on the high speed jet. Pulled the new plugs and checked and sure enough way lean so I turned the high jets to like 1/8 and checked and still really lean. After adjusting them to like 1 and 1/8 turn out it picked up ok but the back cylinder was still lean so I turned just it and I got it smoothed out and it's running pretty good and plug test looks good. I've never seen one be set different. Any thoughts or am I just worrying?
I was thinking an air leak somewhere but not sure. Any suggestions. Thanks in advance.
