Read the owners manual
Way to be helpful and inviting to new people.
You hit the nail right on the head! I don't have a manual and I have no idea why he even posted if he had no help... LoL. Thanks for the supportCorrect.....with a 98 boat maybe he doesn't have a manual handy so he asked the forum.
The trick is to have the DESS in your pocket and not in the dashboard when you jump in the water.Hmm...not sure if I'd be sticking my hand in there while under water, seems like something you'd read about in the obituaries..![]()
Next time you have the boat out of the water on your trailer, get in it and pull the handle (according to the instruction sticker, you probably have to twist it).
Then get out of the boat and climb under it and have a look at the grate with a flashlight.
Even better, if you can get some one else to get in and close the handle while you are under it, then you will get a good look at exactly how it works.
Reach up into the opening, (before they close it) see how far you can reach towards the impeller. Memorize what it all looks like. Sooner or later you are gonna have to get under there and clear something out. I sucked up my tow rope and dove under the boat several times with no idea what I was doing. Better to know what it looks like before you need to do it by feel.
Yeah I would either have it my pocket or out of reach. How did your rope get in there? Did you drive over it?
I have bad luck with rope...twice i picked it up on the mississippi. only 2 times i ever have gotten to take the ol' speedster out. once in the harbor & 2nd time just cruising upstream. I thought of using a bungee cord to tie the weedless handle to the steering wheel if i ever had to go under the boat...also putting the key in with the fire extiguisher & turning the battery off just incase. luckily i was able to limp to shore. I also tried turning the handle to lock the weedless system like the sticker says while out of the water & it seems i'll break the handle off before that happens..turning it either way wont lock it... any ideas on that?
