hi i have a 2007 gti se (155 hp) about 23hrs .i had a small branch in my impeller and it used my wear ring,so i want to the dealer to change the wear ring because i did not have the tool for the impeller. i put the turbine back on my seaddo and after 1 ride i had no take off. took the turbine off again and the wear ring was damage again,the dealer change the wear ring again and they say it fine but it seem that the impeller is not center ,i have 0.98 inch clearence on one side and the other side is .05 inch im not sure if the impeller is not center but the dealer seem to say its ok .the fist time its the impeller itself that gruve the wear ring ,does anyone knows if the impeller as to be perfect center in the wear ring and i know maximume clearence is 1.04inch but what is the minimum clearence.
thanx a milion guys
thanx a milion guys
