how incline do you have to be?
I'm inclined just enough to me dangerous.
My question is to change the impeller and wear ring do you
a) just pull the whole housing off and go at it from the bow side using the impeller tool to remove the impeller, then remove the three screws on the outside of the housing and remove the ring.
or
b) pull everything off from the stern? ie impeller cover, snap ring, impeller shaft, bearing, o ring and sleeve.
Confused in canada
Dean
