Greetings all, do not post very much at all but spend loads of time gathering info. I have a question that I cannot seem to find a consistent answer for. I am looking for the stock pitch size for the impeller on a 2007 GTI SE 155. I purchased it about a month ago and thanks to this site have changed the oil and filter, changed the coolant, replaced the spark plugs, change the OPAS rubber tubes (yes, I am going to keep it} and replaced the wear ring. It runs great with no issues. Had nothing but 2 strokes prior to this one, ( 2002 RXDI, 2001 GTI, 95 GTI, 94 GTI and a 1993 SPX )
When replacing the wear ring it appears that the impeller may not be stock. It is a tad beat up so would like to replace with a different one and a stock pitch one. I have searched all over the place and cannot find a consistent answer to what is the stock pitch impeller. Part # 267000675 I can find a replacements but no one seems to know what pitch it is. I have gotten responses that are 10/18, 11/21 10/21 and even a 12/21. Not looking for an upgrade or aftermarket unless it is the stock pitch. Will most likely buy a used one and clean it up a bit. A new one seems a bit expensive!! But leaving my options open.
Any help in determining the stock pitch would be greatly appreciated!
