SaltyBones
One of the skis will not start. Beeps twice every time. It started to hit a couple times, and even started a couple times for a second or two. Pulled the plugs and they were wet. Put new plugs in it and nothing. Checked the spark at the end of the plug with my finger and it wasn't strong (i could leave my finger over it and keep cranking it, it was that weak). Is that normal for these sea doos? Is it a bad coil causing this?
Also, after cranking it a bit, the negative wire is very hot. Bad ground wire, or normal after cranking the motor awhile?
