Austrian Rotax
hi everyone, still I can't get away from issues with my 96xp one after the other it feels like. now I think its my battery or alternator (I dont know how the charging system works in this doo) Im not sure though, the ski goes from 0 to full throttle no problem with no hesitation whatsoever then once I get to around 45-50 mph it is revving around 6500rpm then after about 10 seconds the RPMs start slowly droping and droping until I let off throttle. Also every time I go above idle on the water the battery light comes on in the dash once I let off throttle the battery light immeditely turns off. it has no hesitatations whatsoever when accelerating just when it gets to WOT the RPMs drop. Carbs and fuel lines done last year.
so I started my trip on the water with my battery sitting at around 12.6 volts and when I put the ski back on trailer to head home it was at 11.85volts 30mins later. I just find it hard to believe the battery is bad since the ski cranks over like it has a new battery in it (battery hasnt been replaced for 1 year now). As a side note the ski did take more cranking then normal to start it. Usually it starts within about half a second of cranking last week. this weekend it took 15 seconds of cranking to start.
Sorry about long story, I just dont want to replace the battery only to find it was my charging system any troubleshooting I can do?
Thanks for any suggestions.
