Hi! Trying to figure why I have some water under the engine? And is it normal..? I just noticed last week after I fixed the IBr Actuator. So maybe now that I pay attention I see this or do I really have an issue?
Today I tried diagnosing it and found myself more puzzled... none of the normal spots had water.. Nothing from the back leaking, not the muffler, the boot around the carbon seal felt dry, none of the bolts from under are leaking (like ride plate).
Please read what i tried..
TEST:
Started fully dry.. and I put the pwc (wake pro 230) on the water. At the dock i inspect and water was starting to accumulate at a noticeable rate.. with a towel I dried all and put my hand under the engine.. couldn't really detect where water is coming from. felFELT AROUND the middle of the engine towards the manifold side (right side when driving). As I dry and let it be... IMPORTANT: I can listen like something either allowing water like gulps gulps etc.. then stops socking water when the bottom of the engine is touching the water...
Is this a mechanical way to cool the engine? Oil pan maybe? After riding water is warm from the engine...
I have not seen the water go beyond the "lower bucket" in the hull. Also if i ride hard.. i see water has been sucked out.
Another symptom that started today.. the engine was stuttering when cold... and vibrating. After a little bit went back to normal... could be remaing gas from last year or sparks coils.. just fyi if means something.
TEST:
