Water In Hull
nuwave
I have a 2007 GTX 155 with 74 hours on it. Never gave me problems till this year.
I got the charging problem fixed now this??? Took the ski out a ride notice thunder clouds coming my way so I headed back to the cottage. Put the ski up on the ramps and pulled the drain plugs and hot water came out. About 3 cup fulls from both sides??? I took the seats off to have a look around and there was nothing noticeable from up top. Are there any problematic areas of this engine where I should focusing on? The ski could sit in the lake statically all day with no water in the hull as it did? Thanks in advance.
Take it back to the ramp, plugs in, seat off, fire it up and see if you see anything obvious.
I'm almost thinking you had water in the hull and the exhaust warmed it up. If you never got on plane, then the water would not have exited.
Do what Joe said and look for a leak at the O.P.A.S. valve, the one just above the jet pump. That was my leak area.
