Just for total transparency, I am a newbie. We had our 2016 GTI 130 winterized and go it back in the water last Saturday. My wife accidentally cross-threaded one of the drain plugs and it sank in 7 ft. of water while sitting overnight. We had it salvaged and brought it home. Needless to say the engine was waterlogged, with a significant amount of water in the crankcase. I used a fluid extractor to remove as much of the water and water/oil mixture as I could through the dipstick hole, added some more oil, took out the plugs, and turned the engine over to get the water out of the cylinders that made its way there through the airbox. I then sprayed WD40 down the spark plug holes to keep the cylinder walls lubricated and to displace any remaining water. I used the extractor to drain the crankcase again, and got even more water and milky-looking oil out.
My question is what do I do now to get the remaining water out of the crankcase? Do I refill with oil, put the plugs back in, run the engine, and then drain the oil again, and continue with that cycle until the oil is clear? Do I put a couple quarts of WD40 in and run the engine a few minutes and then extract it (WD40 would diplace the water but might not provide enough lubrication, even for a short run cycle), and the start the oil refill/drain process? I also pulled the oil filter (which was wet) and will replace that. I feel I've done what I should/could to this point, but don't want to make a mistake and destroy the engine. Anybody have any advice on how to proceed from here?
