So I successfully replaced my wear ring, put a new skat trak impeller in, carbon ring, and all the other parts on the drive shaft without to many problems. I put the boat in the water and it's running rough, so I am looking at pulling the carbs and either cleaning them, or should I get a carb rebuild kit and just redo everything? Also going to clean or replace the rave valves. I can hear the sound of air leaking out/water leaking in underneath the engine, but I cannot see it. No apparent damage on the bottom of the boat so it must be coming through the ride shoe? Any ideas or suggestions would be appreciated.
