Vts error code
dero30
Hi all,
I have a 2005 rxp and I have the error code 1692 coming up on the screen, I have looked it up and it says it is ether high voltage or disconnected in the down trim sensor.
has anybody had this problem? It did say it might be the 7.5amp fuse but it is still ok.
Any help or advise would be great
Cheers
Derek
New Zealand
The VTS seems to be voltage sensitive. I had a battery that worked fine but was starting to go bad. Screwed my VTS all up. Limp mode and 8 codes.
Check to see what your charging volts are. Unplug all the VTS plugs and clean the terminals with a Q-tip and alcohol.
Thanks for that, battery amps are down slightly so will give it a charge and see if that helps, am getting no spark at the moment so it seems to have messed it up a bit.
The only thing I have done prior is take out my fuel pump and replace filters, could be something to do with it.
It ran and for a bit once it was back together, then after giving it a blip on the throttle it stalled and then no spark???
