frogman112
I own a 2004 GTX that I purchased in 2014. I have bad no problems with it except the voltage regulator / rectifier.
When I first purchased it the previous owner had just installed a new battery. I soon discovered that the battery would drain down after several hours on the water. The voltage rectifier was bad and the 30A fuse mounted next to the MPEM (top one) was fried. I replaced both and the charge voltage to the battery was restored to spec.
After a couple of years the R/R went bad again. Fuse was good. Replaced R/R and charge voltage restored.
Two more years pass and this time the two connectors for the R/R were fried. I replaced the R/R and its connectors. Fuse was good. Charge voltage restored.
Now one year later and the battery seems to drain after a couple of hours on the water. The starter does not crank when shut off and started after about 5 minutes. Wait a few more minutes to cool off and it starts back up.
There are no P-codes that cause a beep nor are there any in memory. However, the red light flashes intermediately.
I keep the battery on a Battery Tender when stored. I placed it back on the charger when I got home and it took several hours to fully charge. Placed it back in the ski, base voltage 12.91V. Started engine and voltage increased to 13.88V. The fuse is still good but one blade has developed arc pitting (a multitude of small pits from electrical arcing).
Is it possible for the voltage regulator / rectifier to not be working when it is hot but work ok when it has cooled back off?
Is the arc pitting seen on one blade of the top fuse next to the MPEM caused by a bad R/R that allows A/C voltage from the magneto to travel into the electrical system?
I can not seem to find any information that describes the two separate fuses mounted next to the MPEM. What are these for?
My plan is to check all of the grounded connections that I can see in the harness next.
Frogman112
Frogman112
