Vibration in throttle shifter on hard turn at speed
I was curious if anybody had experienced a hard vibration felt in the throttle controls on a hard turn at speed to the right. I only felt this when driving aggressively and turning hard to the right. As soon as I let off the hard turn the vibration stops. I did not notice this to the left.
Is there an adjustment that I should make?
You might want to check your engine mounts. There is a chance one of them is broken causing it to do this on hard corners. Grab the engine and tug it back an forth to see if moves. Also check all the nuts and bolts in the jet pump assy. for any loose ones.
Karl
I don't think it would be a motor mount issue since their is no shuttering/vibration in any position except hard right. It is not felt at slow speeds (around dock) turned hard right, just at high speed right.
I read this warning from Mercury:
"The shift cable must be adjusted correctly so that the reverse gate does not interfere with water flow coming out of the rudder. If the reverse gate hangs down into the water flow, a vibration may be felt in the control box. If this occurs, reduce throttle immediately and readjust the cable. Improper adjustment may result in pump damage including loss of the reverse gate."
Any advise on adjusting shift cables?
Thanks
Thanks
I actually adjusted the trust cable today. I noticed that the bucket was not resting with tension against the forward stop. There was significant slack in the cable.
What I did was remove the cotter pin holding the cable to the bucket, removed the stainless bracket covering the barrel adjuster and I turned the barrel and checked until it felt like I have slight tension at the front stop and smooth movement of shifter.
Hopefully this fixes my problem. Please advise me if I need to do anything else.
Thank you,
Brian
