97 787 so i did a compression test and 50psi in both ,take off the (head) and they both look good after i did the top end rebuild the boat set for 8months befor it was ever started up, so do i need to do the rings again?i cant bore them again as they are 1mm pistons
could it just be the rubber rings that go around the top of the pistons on the cylinder???im just glad both pistons and rings are hole
