I got my first taste of jet power today as a owner, both the good and the bad. I launched my 05 Speedster 200 (rotax/370hp) today and was having a blast. Decided to go down to the "party beach" area, which is at the end of the lake going through a mile or two of no wake zone. Probably to due the lack of wake, and the current down there, it allows a lot of debris to be at the surface... branches, weeds, etc...
I did my best to avoid debris, but I apparently I sucked some up. I ran the ICS, did the reverse trick mentioned somewhere here, etc... but couldn't get it out. The left engine ran fine. The right one, however, had no power and reached high RPM very quickly and would make a terrible sound like it was vibrating, as it the engine was loose and unbalanced.
Got it back on one engine and brought it home. What I see is what looks like a birds nest of "river weeds" tangled in the impeller.
I see no problem with the the surrounding ring. I have the 3 tine ICS style grate. I assume I just remove the hex bolt that attached it to up/down arm to lower it and reach in there?
1) Any tips on getting stuff out? Do you take a knife to it, pliers, or anything that will work? Don't want to cause damage trying to remove it, so asking for tips first.
2) Is the symptoms I described sound typical? Why did the RPMs so readily run up like that giving it just a little gas? Is it because it was jammed so the clutch was slipping, so it was free spinning without resistance?
Sorry for the basic questions, just trying to get used to all of this. =)
