wizardsrevenge
Hi. Well I melted the t-pipe fitting in the rear exhuast twice now. I went through the entire cooling system and found that the tuned pipe lower water jacket is restricted somewhere. Basically I just pulled each hose and tried to blow air or water through each line.
I have no idea what is causing the block. Looks like I have to remove the tuned pipe to get a better look. Is there a way to clear the blockage without removing the tuned pipe? Coolant flush that dissolves particles? A fish wire that I can feed through the hose and or water jacket?
Again this is the cooling line the tees off the just before the engine intake then runs through the lower pipe water jacket exits the bypass then back to the exhaust and into the water trap. thanks for the and info and help.
