Hey guys...I am having issues starting the boat. I originally thought it may have been the battery b/c I hooked a charger up to it and it had less that 15% charge. Well now it's at about 100% and I'm still getting nothing when I hit the the start buttons...When nothing happens, I get into the bilge and remove the spark plug cables from the plugs, rub the top of the plugs and replace the cables..sometimes it works, sometimes it doesn't. When I do get it running, the engines idle +/- 1500 rmp and they run strong wide open no issues...but then I will cut off the engines, to swim or what not, and they won't cut back on until after a few minutes...
I replaced the plugs on the left engine (only had two sitting around..I have two more coming for the right), which seemed to help out at first, but now the problem is back (this has been a recent development).
Today I got the boat running and it was doing great, after about 15 mins I was bringing her back to the dock at idle and after being in idle for about 1 min, the boat cut out and wouldn't cut back on no matter what I tried...I had to paddle in.
What else could it be? Even if the battery is showing a charge, could that be the problem? I use ethanol free gasoline with seam foam and sta-bil, I clean the fuel filters everytime before I take the boat out...
