Assuming you have to disassemble some positioning linkage, try not to change the adjustment on any of the linkage pieces, otherwise the ignition timing will be off.  The position of the parts in reference to the crankshaft and throttle is muy important.
So, just remove the linkage cotter pins or clips instead of unscrewing the adjusters, then you can reassemble in the same relative position.
