Howdy all....eager to begin another season of boating but trying to address some issues that I encountered at the end of last to get my trailer back in compliance. Noticed that the rear lights were no longer functioning (most likely due to them not being water tight...found out the hard way)...no big deal but figured instead of dealing with incondescents burnin out i replaced them with LED's...or almost did....can't seem to get the drivers side light to work....pulled some of the wiring out of the frame and found that there was quite a few connections for what I'd assumed would or could be a simpler diagram. From all the diagrams I've seen none seem to address the 7 wires i have running into a four plug connector....it appears i have addtn'l lights on the stem of this trailer but am assuming, again, that they simply tie off the brown wire (steady burn)....regardless what i'm tryn to get at is i was considering replacing the main plug from the trailer since one of the rods appears to be worn down and may be the root of the problem...any one have a clue as to what i may be getting my self into if i simply cut it off and go by trial and error at which wires are tied together into the same plug rod on the connector?
