Tow hook plastic housing loose 99 GSX
jimcrisp
Premium Member
Premium Member
The plastic housing under the front tow hook has come loose. Water is able to get in through front housing. How can I reattach it?
there should be two nuts on the inside front that probably have worked their way loose. look from there with a flashlight and you'll see them. if its damaged you can always get a complete replacement cheap.
Thanks for your response. Awesome. However, when I try to look in my gas/oil tank obstructs any view. How do I see it or access it? What am I missing? The hook is not loose at all -- just the plastic housing.
