Throttle adjust
s022mag
My throttles aren't even at mid range, I know they're not going to be perfect but there about a inch apart. They both idle the same but my starboard throttle does not increase RPMs until I'm almost 3/8th up. The port responds a little quicker. When investigating near the carbs I feel a lot of play in the Starboard side, I pulled up the shifter and throttle cluster and notice the throttle cable moves as soon as the throttle moves, so there just must be to much slack in the line. Is there a inline adjust on the cable?
I’m not sure which boat you’re working on, but they should all have an adjustment at the throttle linkage end and at the carb end.
I found a adjuster about 6" from the carb. I was able to adjust it to get it to match closer to the port engine. I know they will still be off but this should be better than before.
